12-10-2008 01:19 AM - edited 03-06-2019 02:53 AM
I have a cluster of 4 catalyst 2950.
The IOS is 12.1(22)EA12 with crypto and web device manager.
The SSH et HTTP server are activate.
The memory usage is always upper than 85%. Consequently, I get this message :
Nov 28 07:57:27: %SYS-2-MALLOCFAIL: Memory allocation of 98912 bytes failed from 0x803B6798, alignment 0
Pool: Processor Free: 49968 Cause: Not enough free memory
Alternate Pool: I/O Free: 341564 Cause: Memory fragmentation
How can I solve this problem ?
12-10-2008 01:42 AM
Hi Hugo,
Is there any sort of like Network Control, MAC security or SPAN on it ?
DAK
12-10-2008 02:01 AM
No
However this switch is in a cluster (4 members).
Extract of show tech :
32768 bytes total (15169 bytes free)
------------------ show process memory ------------------
Total: 6065568, Used: 5327772, Free: 737796
PID TTY Allocated Freed Holding Getbufs Retbufs Process
22 0 760967264 760967080 3992 0 0 Calhoun Statisti
30 0 247568652 242761968 14116 4709116 4652896 IP Input
54 0 478374272 478371792 8988 0 0 Cluster Base
58 0 210309032 211563788 20616 0 0 Key Proc
75 0 2323718548 3152886732 132236 0 0 SNMP ENGINE
79 0 262488796 262488796 12808 0 0 Cluster Cmdr
5315252 Total
------------------ Mempool statistics ------------------
Head Total(b) Used(b) Free(b) Lowest(b) Largest(b)
Processor 80C86660 3885472 3849808 35664 1556 524
I/O A0A72240 2180096 1477548 702548 152676 365256
12-10-2008 02:20 AM
Could you please check if there is any change in STP configuration.
DAK
12-11-2008 09:34 PM
Hi Hugo,
Could you please paste show pro cpu sorted detail.
Chao
Vishwa
