ACE redirect to maintenance url when real server is not avaliable
Dec 10th, 2008
Dear all i have ace behind there is 2 real server,i have already done a redirection http to https its working fine,now i want redirect to new you url (diffrent server) when my real servers is outofservice, how can acheive this task please help, i have attached my configuration thank you very much
Overall Rating: 5 (1 ratings)
Gilles Dufour Mon, 12/15/2008 - 02:53
  • Cisco Employee,
The idea is to create a redirect serverfarm that you configure as backup for your main serverfarm with your 2 rservers.
Gilles.
rajesh.perumalla Mon, 12/15/2008 - 16:44
Modify the policy-map as below and check whether redirect is working when the real servers are down.
policy-map type loadbalance first-match HTTP2HTTPS-POLICY
class class-default
serverfarm HTTP2HTTPS-SF primary SHUTDOWN backup
hbhupesh1 Sun, 12/21/2008 - 21:40
Thank you for your reply. In configuration I did not find command "serverfarm HTTP2HTTPS-SF primary SHUTDOWN backup". I am running below version
Cisco Application Control Software (ACSW)
TAC support: http://www.cisco.com/tac
Copyright (c) 2002-2008, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Software
loader: Version 12.2[120]
system: Version A2(1.0a) [build 3.0(0)A2(1.0a) adbuild_04:14:49-2008/04/18_/auto/adbu-rel3/rel_a2_1_throttle/REL_3_0_0_A2_1_0A]
system image file: [LCP] disk0:c6ace-t1k9-mz.A2_1_0a.bin
installed license: ACE-SEC-LIC-K9
Hardware
Cisco ACE (slot: 4)
cpu info:
number of cpu(s): 2
cpu type: SiByte
cpu: 0, model: SiByte SB1 V0.2, speed: 700 MHz
cpu: 1, model: SiByte SB1 V0.2, speed: 700 MHz
memory info:
total: 956180 kB, free: 253656 kB
shared: 0 kB, buffers: 4680 kB, cached 0 kB
cf info:
filesystem: /dev/cf
total: 1000512 kB, used: 390320 kB, available: 610192 kB
last boot reason: reload command by admin
configuration register: 0x1
NR-1-ACE kernel uptime is 104 days 17 hours 35 minute(s) 0 second(s)
Here are configuration option I see in my ACE;
NR-1-ACE/ADMIN-CLIENT(config)# policy-map type loadbalance first-match HTTP2HTTPS-POLICY
NR-1-ACE/ADMIN-CLIENT(config-pmap-lb)#
NR-1-ACE/ADMIN-CLIENT(config-pmap-lb)# class class-default
NR-1-ACE/ADMIN-CLIENT(config-pmap-lb-c)# serverfarm ?
Enter serverfarm name (Max Size - 64)
HTTP2HTTPS-SF
SERVERFARM-1
SHUTDOWN
NR-1-ACE/ADMIN-CLIENT(config-pmap-lb-c)# serverfarm HTTP2HTTPS-SF ?
backup Specify backup serverfarm
Carriage return.
I did try to configure with backup command but did not help either.
sh rserver SHUTDOWN-Redirect shows it is operational but does not detect and redirect when real servers are down for maintenance.
NR-1-ACE/ADMIN-CLIENT# sh serverfarm SHUTDOWN
serverfarm : SHUTDOWN, type: REDIRECT
total rservers : 1
----------connections-----------
real weight state current total failures
rserver: SHUTDOWN-Redirect
0.0.0.0:0 8 OUTOFSERVICE 0 0 0
NR-1-ACE/ADMIN-CLIENT# sh rserver SHUTDOWN-Redirect
rserver : SHUTDOWN-Redirect, type: REDIRECT
state : OPERATIONAL (by default, unverified)
serverfarm: SHUTDOWN
Appreciate your input. Thank you in advance.
Bhupesh
rajesh.perumalla Tue, 12/23/2008 - 03:05
Bhupesh,
Define the backup serverfarm configuration as below
sticky ip-netmask 255.255.255.0 address source STICKY_IP
timeout 15
replicate sticky
serverfarm SERVERFARM-1 backup SHUTDOWN
hbhupesh1 Thu, 02/05/2009 - 14:40
Hey Rajesh,
Its working... Sorry for late reply but I could not do it earlier.
Thank you very much for your suggestions.
Bhupesh
michal.jurco Mon, 01/10/2011 - 03:35
Hi Rajesh,
but accoding to Cisco documentation if you configure backup serverfarm within sticky-group configuration mode, then also backup serverfarm will become sticky. And i would say that this is undesired in this case. Because with sticky backup serverfarm only new connections will be directed to primary serverfarm (when servers are operational again) and all sticky connections will be still directed to backup serverfarm. Or do you think that this doesnt apply if backup serverfarm is redirect type?
"Backup Server Farm Behavior with Stickiness
When you associate a server farm with a sticky group using the serverfarm command in sticky configuration mode, the primary server farm inherits the stickiness of the sticky group. The ACE sends requests from the same client to the same server in the primary server farm based on the type of stickiness that you configure in the sticky group. If you also configure a backup server farm using the optional backup keyword of the same command, the backup server farm automatically becomes sticky, too, regardless of whether you configure the sticky option or not.
If all the servers in the primary server farm go down, the ACE sends all connections to the backup server farm. When the primary server farm comes back up (that is, at least one server becomes active), existing connections to the backup server farm continue to be serviced by the backup server farm. The ACE also sends new requests for existing sticky connections to the backup server farm.
The ACE sends all new connection requests to the primary server farm. Such requests include those for which there is no entry in the sticky table, the sticky entry aged out, or the ACE overwrote the sticky entry because the sticky table was full.
If you want to configure a sorry server farm and you want existing connections to revert to the primary server farm after it comes back up, do not use stickiness"
Thank you.
Michal
