ASDM 5.2 for ASA 5505 7.2(3)
Dec 10th, 2008
Can anyone help out on this.
I try, with ASDM 5.2, to load the configuration from a brand new ASA 5505 with default config. I get the question for username and password (blank) and login. ASDM starts loading the config and then it pops up with ERROR :
ASDM is unable to read the configuration from the ASA. Please check the confguration and yor connection and try again by clicking the Refresh icon.
I can telnet to the ASA, so the connection is OK. And https is OK to.
I tried the same action from a borrowed PC and this works OK. So the problem must be my PC.
Any suggestions?
JORGE RODRIGUEZ Wed, 12/10/2008 - 14:36
The problem could be the java version you are running on the problem pc, I would suggest to update to the latest java version.
