3845 Terminal Server Issues - Line Busy
patrick.roche
Hello, we seem to have experienced a problem when upgrading some of our Cisco terminal severs (3845s) to c3845-ipbasek9-mz.124-21.bin.
Certain Terminal lines would say they were in use when trying to connect.
Any ideas?
carenas123
Level 5
Level 5
Make sure that the async lines use the minimum configuration of the transport input telnet command. So you can Telnet to the devices on the async line.
For the further description following URL may help you for the configuration
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a008014f8e7.shtml
The config is fine. Here is some more info:
Requested line is busy
If I do a show line or show user for the particular line that reports the message it shows it's not in use, the only other message that we see in the logs after a reload was the following.
%SYS-3-HARIKARI: Process SSH Process top-level routine exited
