Gilles Dufour Thu, 12/11/2008 - 04:07
Aghi,
what device ?
Cookie sticky is normally possible on CSM and ACE.
With the CSS you need to configure arrowpoint cookies.
Gilles.
aghibear1 Thu, 12/11/2008 - 05:47
i have CSM module in my 6509.it's possible redirect 2 different flow to the same real server?maybe url sticky strings?
client1 and client2 must be redirect to the same real server for properly work.
tks
Aghi
Gilles Dufour Mon, 12/15/2008 - 02:41
Aghi,
if they contain the same cookie information, you can configure the same sticky group under the 2 vserver and if the client sends the same cookie, the traffic will be sent to the same server.
You can even create static entries to control the server you want to select.
Here is an example assuming the servers return a cookie called MyCookie.
You don't need the static entries.
I just show it to inform you this is possible.
gdufour-cat6k-2(config)#mod csm 3
gdufour-cat6k-2(config-module-csm)#stick
gdufour-cat6k-2(config-module-csm)#sticky ?
<1-255> sticky group ID
gdufour-cat6k-2(config-module-csm)#sticky 1 ?
cookie configure sticky group cookie
header configure sticky group header
netmask configure sticky group IP netmask
ssl configure sticky group ssl
gdufour-cat6k-2(config-module-csm)#sticky 1 cook
gdufour-cat6k-2(config-module-csm)#sticky 1 cookie ?
WORD cookie name 1-63 characters
gdufour-cat6k-2(config-module-csm)#sticky 1 cookie MyCookie ?
gdufour-cat6k-2(config-slb-sticky-cookie)#stat
gdufour-cat6k-2(config-slb-sticky-cookie)#static ?
cookie sticky entry based on a cookie value
gdufour-cat6k-2(config-slb-sticky-cookie)#static coo
gdufour-cat6k-2(config-slb-sticky-cookie)#static cookie ?
WORD cookie value string
gdufour-cat6k-2(config-slb-sticky-cookie)#static cookie server1 ?
real specify real server
gdufour-cat6k-2(config-slb-sticky-cookie)#static cookie server1 real
gdufour-cat6k-2(config-slb-sticky-cookie)#static cookie server1 real ?
A.B.C.D real server IP address
gdufour-cat6k-2(config-slb-sticky-cookie)#static cookie server1 real 1.1.1.1
aghibear1 Wed, 12/17/2008 - 08:14
hi,
tks for the reply........i try in my configuration
best regards
Aghi
