dail-peer not working
Answered Question
Dec 10th, 2008
Dial peer 14 is not working:
http://pastebin.ca/1281736
debug voice dialpeer inout:
Dec 10 16:30:47.846: //-1/BC172FC2B698/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=103
Dec 10 16:30:47.850: //-1/BC172FC2B698/DPM/dpMatchPeersCore:
Calling Number=, Called Number=2142346837, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=2142346837
No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
Dec 10 16:30:47.850: //-1/BC172FC2B698/DPM/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
Correct Answer by allan.thomas about 8 years 7 months ago
Hi Shaun, when you show dial-peer voice summary, what is the status of the dial-peer 114? Up or Down?
What I have noticed is that the trunk group label that you have assigned does not have any active voice-ports. Therefore I suspect that it is down.
Should the trunkgroup label be 'trunkgroup Local' and NOT 'trunkgroup local'?
Hope this helps
Allan.
Overall Rating: 5 (1 ratings)
Correct Answer
allan.thomas Wed, 12/10/2008 - 09:11
  • Blue, 1500 points or more
Hope this helps
Allan.
sdaniels44 Wed, 12/10/2008 - 09:19
Im an idiot, thanks for your help.
local should have been Local. It is case sensitive.
You were right.
