Password change from SSH in Cisco Secure ACS 4.1
Dec 10th, 2008
I am using cisco ACS for windows Release 4.1(1) Build 23 Patch 5.
I have enable password aging for 30 days. after 30 days it is prompting me to change the password while i telnet to any client. it is working fine.\
Recently we have disabled telnet in all network devices and using ssh instead of telnet.
Am not able to change the password from putty. same if i connect through the telnet it is prompting to change the password.
Because of this i am not able to access any network devices after 30 days.
Suggestions will be greatly appreciated.
Thanks in advance.
cisco24x7 Wed, 12/10/2008 - 08:27
Went through this painful exercise a couple
weeks ago. You need to use the IOS 12.4
K9 image on the routers because password change
only supports on ssh version 2. See example
[[email protected]]# ssh -2 -l ngx1
[email protected]'s password:
Password change request
Enter [email protected]'s old password:
Enter [email protected]'s new password:
Retype [email protected]'s new password:
C3640>sh ver
Cisco IOS Software, 3600 Software (C3640-JK9O3S-M), Version 12.4(13a), RELEASE SOFTWARE (fc1)
Technical Support:
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Tue 06-Mar-07 20:25 by prod_rel_team
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
C3640 uptime is 1 week, 5 days, 13 hours, 5 minutes
System returned to ROM by reload at 03:18:41 UTC Fri Nov 28 2008
System restarted at 03:20:58 UTC Fri Nov 28 2008
System image file is "flash:c3640-jk9o3s-mz.124-13a.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 3640 (R4700) processor (revision 0x00) with 98304K/32768K bytes of memory.
Processor board ID 24829119
R4700 CPU at 100MHz, Implementation 33, Rev 1.0
2 FastEthernet interfaces
4 Serial interfaces
1 HSSI interface
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
Easy right?
psureshrao Thu, 12/11/2008 - 01:15
First of all i would like to thak you for your reply.
Is there any cisco document suggesting this (before 12.4 IOS doesn't support SSH password change )? If so can you please provide me the link, so that i can show the proof to my management.
cisco24x7 Thu, 12/11/2008 - 03:57
This comes directly from Cisco TAC. Cisco TAC
is the best in the business, bar none. IOS
12.3T, if I understand it, is equivalent to
IOS 12.4 main line. Here is Cisco TAC
response below:
Password change is supported by SSHv2. SSHv1 doesn't support the necessary message types to initiate a password change sequence.
The issue you are facing is another known bug apart from the bug I provided earlier “CSCdy54970”. Here is the new bug id: CSCin91851
Only the very latest versions of IOS code (K9 image) on the routers support SSHv2.
In the mean time, I am sending you one link regarding SSHv2 and supported IOS
