Warning message
7921/25 Push To Talk
Dec 10th, 2008
I was just wondering if the only way to use the Push to talk feature on these wireless phones is to implement the IPICS solution. If not, can someone point my in the installation directions?
Rob Huffman Wed, 12/10/2008 - 09:21
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Joseph,
As far as I know this is still the only way :(
This is not a built-in service (at least yet). Have a look at the following;
Q. Is Push-to-talk (PTT) natively supported on Cisco Unified CallManager or does it require a third-party application and server?
A. PTT is not supported natively on Cisco Unified CallManager. To support PTT, the Cisco Unified Wireless IP Phone 7921G relies on support via an XML application.
Q. How is PTT different on the Cisco Unified Wireless IP Phone 7921G compared to the Cisco Unified Wireless IP Phone 7920?
A. The Cisco Unified Wireless IP Phone 7921G has a dedicated application button that supports PTT via XML; the Cisco Unified Wireless IP Phone 7920 uses soft keys for PTT.
Q. Does the Cisco Unified Wireless IP Phone 7921G support XML?
A. Yes. In fact, several third-party vendors are building XML applications that work with the Cisco Unified Wireless IP Phone 7921G.
From this doc;
http://www.cisco.com/en/US/products/hw/phones/ps379/products_qanda_item0900aecd80601788.shtml
Check out Berbee (Push to Talk)
http://www.cisco.com/comm/applications/IPCApps/Docs/berbeecollateral.pdf
Hope this helps!
Rob
hankej@ntc.edu Wed, 12/10/2008 - 10:56
Thanks Rob,
That's what I thought. Luckily, we're going to get a quote on IPICS.
Jonathan Schulenberg Wed, 12/10/2008 - 11:37
    2017 IP Telephony
I believe CDW and LiteScape also make push-to-talk applications.
Cisco at one point or another was going to OEM the LiteScape product into CUAE but I'm not sure if that ever happened.
