A PIX Command to SHOW RUN brief
Answered Question
Dec 10th, 2008
Right now my pix will show the entire config in one fail swoop. I need to break it down to so many lines. I've tried goggling it but no such luck so far. I need to change it and make it permanent so that every time I open it up it will stay at that level?
Please give me a link to the proper command or a suggestion on how to do this?
Correct Answer by ajagadee about 7 years 10 months ago
In Pix 6.x, you could use
In Pix 7.x and higher,
Terminal pager
*Pls rate if it helps*
Overall Rating: 5 (2 ratings)
rbill1967 Tue, 03/31/2009 - 13:27
Thanks for the Help it did resolve it. Sorry I forgot I made the request for assistance.
If at all possible how would I make it permanent. I've done this and after so many connections I have to do it again.
John Blakley Wed, 04/01/2009 - 08:45
After you make the change, you should be able to write the config to make it permanent.
rbill1967 Wed, 04/01/2009 - 08:51
Unfortunately that did not work, after a couple of days it defaults to showing all of it at once.
Any other suggestions?
John Blakley Wed, 04/01/2009 - 08:55
Not really. It's part of your config, so writing it should keep the changes. If you're losing the changes, I think you have a larger problem.
If you do a "sh run | inc pager", what do you see?
What version are you on, and what PIX version is this?
rbill1967 Wed, 04/01/2009 - 08:58
I see the following.
PIX525# sh run | inc pager
pager lines 30
Cisco PIX Firewall Version 6.3(4)
Cisco PIX Device Manager Version 3.0(3)
John Blakley Wed, 04/01/2009 - 09:00
If you change that to what you want, and do "sh run | inc pager" again, do you see the changes?
If so, you should do "wr mem". After that, try "show start | inc pager" and see if your changes are there. If they are, you shouldn't be losing the changes on reboot.
rbill1967 Wed, 04/01/2009 - 09:24
Okay lets see, and I will let you know in a few days.
rbill1967 Mon, 05/04/2009 - 08:08
Just to keep you updated, I did the wr mem and it kept it for awhile. After awhile it reverted back. It there something else I should be looking at?
