VG224 MGCP Port Configuration
Dec 10th, 2008
I am configuring a VG224 via MGCP and callmanager 7.0 to support 24 fax machines. I am running into two questions.
When I create the ports should I set them as POTs ports or FXS ports? I'm not exactly sure what the differance is.
Also what exactly do I put in the Attendant DN box? Do I set that to the same phone number as the line I will create?
iptuser55 Fri, 12/12/2008 - 08:23
When you configure the 224 as MGCP, the CCM option is only POTS. You then configure via CCM page the DN on the line
NPT_2 Fri, 12/12/2008 - 08:31
The strange thing is that callmanager 7 actually gives me POTs and FXS. I'll just configure for POTs. Thanks for the info.
