Pix 506E VPN and Remote Access
Dec 10th, 2008
I keep revisiting setting up rdp over VPN with a pix 506e. It works, then fails, I give up, try again, etc... Anyway, I am able to establish the vpn. However, I can't consistently connect to one of the machines on the inside. Here is my config and I would appreciate any help.
interface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list inside_outbound_nat0_acl permit ip any 192.168.2.0 255.255.255.224
access-list outside_cryptomap_dyn_20 permit ip any 192.168.2.0 255.255.255.224
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside X.X.X.X 255.255.255.0
ip address inside 10.1.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool ippool 192.168.2.1-192.168.2.29
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 X.X.X.1 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 10.1.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
isakmp enable outside
isakmp identity address
isakmp nat-traversal 20
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
vpngroup vpn3009 address-pool ippool
vpngroup vpn3009 dns-server X.X.X.X X.X.X.X
vpngroup vpn3009 idle-time 1800
vpngroup vpn3009 password **********
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 10.1.1.2-10.1.1.254 inside
dhcpd dns X.X.X.X X.X.X.X
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
terminal width 80
John Blakley Wed, 12/10/2008 - 12:04
  • Purple, 4500 points or more
Where is the terminal server? Is it on the opposite side of the VPN or on this side? If it's on this side, is it on the same subnet as the pix inside interface, or is there another device that's routing for you in between?
HTH,
John
peteb41976 Thu, 12/11/2008 - 05:53
Terminal Server is on the inside - 10.1.1.2 directly attached to the pix. There is another nic on the server - 192.168.1.95 - which is attached to my internal network subnet.
ajagadee Wed, 12/10/2008 - 12:50
  • Cisco Employee,
Is this happening for all Remote VPN Clients or specific users. Have you checked the MTU Settings on the Client side. Try lowering the MTU to 1300 or below and see if the problem goes away.
Arul
*Pls rate if it helps*
ajagadee Thu, 12/11/2008 - 08:40
  • Cisco Employee,
Check the IP Address of Routing on the server. I see that you are assigning IP Address via DHCP to the clients behind the Pix and this includes the 10.1.1.2 address. DHCP is not the best/optimal way to assign ip address to a server, because we dont know if the server will get the same ip address every time. So, I would recommend that you hardcode the IP Address on the Server and also remove the 10.1.1.2 from the range of DHCP Address.
Also, If you configure a static address on the server, make sure the default gateway is pointing to the Pix or a route for the VPN Pool of IP Addresses is added on the server.
Arul
ajagadee Thu, 12/11/2008 - 08:41
  • Cisco Employee,
Thanks for the info. As per my previous post, check the routing first and then if you still run into any issues, post the updated configuration along with show crypto isakmp sa and show crypto ipsec sa and we will investigate the issue further.
Arul
peteb41976 Fri, 12/12/2008 - 07:38
Here is the new config.
names
pager lines 24
mtu outside 1500
mtu inside 1500
pdm history enable
arp timeout 14400
route outside 0.0.0.0 0.0.0.0 X.X.X.X 1
http server enable
floodguard enable
vpngroup vpn3009 dns-server 10.1.1.1 X.X.X.X
vpngroup vpn3009 password *************
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd lease 3600
terminal width 80
ajagadee Wed, 12/17/2008 - 21:57
  • Cisco Employee,
Are you still having issues connecting to the server. Can you post the output of "show cry is sa" and "show cry ips sa" when the vpn client is connected and trying to ping the server.
What about the routing on the server? Is it configured correctly to route the packets for the VPN pool of ip addresses back to the Pix.
Arul
*Pls rate all helpful posts*
