4402 version 5.2.157 https issue
Dec 10th, 2008
  • Silver, 250 points or more
I met some strange things when using 5.2.157 at 4402-50, previous version is 3.2.195, I upgrade it to 5.2 by 4.1.185->4.2.176->5.2.157. After upgrade, I can use https to login to the controller, I can create new interface, however when I try to click the WLAN I created when using console to do the initial configuration, the IE(I'm using IE 6.0.2900.2180.XPSP_SP2_qfe.070227-2300) told me "error on the page", and I can't open the WLAN I created. Then I use the GUI to create another WLAN profile, after I type in all the parameters for this WLAN, and click APPLY, then suddenly I lost https connection. After I enable http access, I can use http to login to the WLC, but still can't use https to login. System time is correct, https certificate is valid. I have tried to delete the new WLAN I created, after deletion, https still can't work, but http can work. I also tried to reboot WLC, power down wlc then power up, still the same.
I will try to delete the certificate and re-generate it and find another version web-browser to try again tomorrow. However before that, I'd like to find out if anybody had seen it previously and what's the solution. Thanks for any input.
Scott Fella Wed, 12/10/2008 - 16:18
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Post your show run-config so we can see if its a configuration issue or not.
miller-p Fri, 12/12/2008 - 17:44
I had a few problems as well. I started using Firefox, due to some policies being pushed to my browser that I can't control.
bbxie Mon, 12/15/2008 - 23:48
this is a cisco bug, similar as what described in CSCsv77075
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
