Issue Routing with Cisco 851
Dec 10th, 2008
After talking with a cisco agent. I purchase the cisco 851 without wireless. I need to configure one fast ethernet with ip.ip.ip.ip 255.255.255.240 and another fastethernet with ip.ip.ip.ip 255.255.255.248. Is it possible to turn 1 fast ethernet from the managed switch into another wan port.
Overall Rating: 3 (1 ratings)
Giuseppe Larosa Wed, 12/10/2008 - 23:53
  • Hall of Fame,
    Founding Member
Hello Stephane,
if your 851 has 4 ethernet ports they are already a small switch.
You can connect one port to another switch you may need to use a cross-over cable.
the ports are L2 and you need to associate them with Vlans
Some releases support only two vlans
vlan 1
name first
vlan 2
name second
int fas1
switchport
switchport mode access
switchport access vlan 1
int fas2
switchport
int fas3
switchport
int fas4
switchport
switchport access vlan 2
desc to other switch
int Vlan1
! very important
no shut
int Vlan2
! very important
no shut
Hope to help
Giuseppe
royalblues Wed, 12/10/2008 - 23:56
  • Green, 3000 points or more
you can use the fastethernet port as wan and use one of the ports of the switch for the managed lan by assigning an IP to the VLAN SVI
Narayan
Edison Ortiz Thu, 12/11/2008 - 06:19
  • Hall of Fame,
    Founding Member
You can't apply the IP address directly under the fastethernet interface but you can associate the fastethernet to a virtual interface as Giuseppe illustrated and still perform the same functions.
HTH,
__
Edison.
stephaneatbercell Thu, 12/11/2008 - 07:04
Hi Edison,
If I set FasEthernet4 to
desc To cable modem
ip address ip.ip.ip.ip 255.255.255.240
no ip redirects
no ip unreachable
half-duplex
no shutdown
Then I set VLAN 1
desc to customer network
ip address ip.ip.ip.ip 255.255.255.248
and assign VLAN 1 to lets say fastethernet0.
I would be able to route information between both.
as if i would of setup the VLAN as a secondary WAN port.
Stephane
Edison Ortiz Thu, 12/11/2008 - 07:08
  • Hall of Fame,
    Founding Member
Correct.
