duplex mismatch
tarunutl1
sir,
I am getting log in cisco router for sub-interface- duplex mismatch discovered on GigabitEthernet0/1.2 (not half duplex), with SEP00170EF9E8B6 Port 1 (half duplex).
I must have to set duplex and speed auto in interface gi0/1 for other VLAN.
How to solve this.
Plz, help.
Tarun
Giuseppe Larosa
hello Tarun,
these messages usually are CDP derived.
Another thought is that speed and duplex are physical properties that can be configured only on the physical interface gi0/1.
So a complain for duplex mismatch is a true issue only if it is seen in
sh int gi0/1.
Then the IP phone should be the first device out the port.
In this case you should change the cable or verify cabling it can be a cable issue
or access via web the ip phone page and check for collisions errors or other signs that is putting the link in half duplex.
Hope to help
Giuseppe
