LMS 3.1 Install the applications
Dec 10th, 2008
Hi pros,
I have done the initial setup of the lms3.1 with common service and network asistant and portal. Now how can i add other apps such as CM,DFM,IPM,RME.
In the portal page i could not find how to install those apps.
Please help me.
Note: During the setup when i selected all the applications and enter the license, it gave license not valid.
So i choose only CS,NA,Portal.
But i found other 4 apps are licenssed.
please help me
thanks
swami
Joe Clarke Thu, 12/11/2008 - 06:43
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Simply install the other apps from the DVD. Once you have Common Services installed, you can just select the individual other applications from the list of available applications on the DVD. If you don't have a license yet, you can install them in eval mode. The evaluation period lasts for 90 days.
arumugasamy Thu, 12/11/2008 - 21:40
When i open the DVD it goes again for the fresh install. In porttal page cann't we install the rest of the apps.
Shall i uninstall the lms and reinstall with all required apps?
swami
Joe Clarke Thu, 12/11/2008 - 23:18
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
It sounds like your first installation might have been bad. Yeah, I would uninstall, and reinstall the applications you want from scratch.
arumugasamy Sun, 12/14/2008 - 05:26
Thanks for your suggestion. I will reinstall the server.
Samy
