ASA/PIX Dos Mitigation
Dec 11th, 2008
Hi All,
I have the following scenario;
Hacker or virus ---> ASA/PIX MPF ---> Router or Device endpoint
I use syslog traffic in this example but I have done it with ICMP, telnet etc .... The idea is to drop the traffic based upon the class-map.
class-map hack
match port udp eq 514
policy-map inside
class hack
set connection conn-max 1
police input 8000 conform-action drop exceed drop
service-policy inside interface inside
I'm getting matches against the service-policy but the traffic doesn't drop ...
Interface inside:
Service-policy: inside
Class-map: syslog
Set connection policy: conn-max 1
current conns 1, drop 0
Input police Interface inside:
cir 8000 bps, bc 1500 bytes
conformed 3 packets, 375 bytes; actions: drop
exceeded 0 packets, 0 bytes; actions: drop
conformed 80 bps, exceed 0 bps
vvarakan Thu, 12/11/2008 - 10:06
You current connection count is only 1 so you will not see any drops.
jon.humphries Sun, 12/14/2008 - 08:11
It looks like my issue, was that the CIR police mechanisim is there for rate limiting as opposed to dropping the connection.
I misunderstood the functionality of this feature.
Many thanks for your input.
Jon Humphries
