CME 4.0 - DnD Issue
Answered Question
Dec 11th, 2008
I'm using IOS 12.4(9)T7 SP Services.
Phone firmware is 8.0.4(SR2)S (compatible for CME4.0(0).
When DnD is enabled, and I press 'DnD' softkey again, I need to wait about 23-24 seconds before the DND is actually disabled.
Is this a known issue? I tried searching the forum and found a few issues with removing DnD but not quite what I see.
I did a bug search on 'dnd', also can't find anything.
Here's my telephony service config and ephone-template:
telephony-service
load 7910 P00403020214
load 7960-7940 P00307020200
load 7914 S00104000100
load 7941 SCCP41.8-0-4SR2S
load 7961 SCCP41.8-0-4SR2S
load 7936 cmterm_7936.3-3-5-0
max-ephones 50
max-dn 50
ip source-address x.x.x.x port 2000
timeouts interdigit 5
system message Datacraft Singapore
url services http://x.x.x.x/voiceview/common/login.do
url authentication http://x.x.x.x/voiceview/authentication/authenticate.do
network-locale GB
time-zone 42
time-format 24
date-format dd-mm-yy
dialplan-pattern 1 65935... extension-length 4
voicemail 5389
max-conferences 8 gain -6
call-forward pattern 9........
call-forward pattern ....
moh music-on-hold.au
multicast moh 239.10.16.4 port 2000 route x.x.x.x
web admin system name CCMAdministrator password password
web admin customer name ELAdmin password password
dn-webedit
time-webedit
transfer-system full-consult
create cnf-files version-stamp 7960 Dec 11 2008 11:55:24
ephone-dn-template 1
description For Users with Voice Mail
call-forward busy 5389
call-forward noan 5389 timeout 18
pickup-group 8000
huntstop channel
ephone-dn-template 2
description For Users without Voice Mail
pickup-group 8000
huntstop channel
ephone-template 1
softkeys idle Redial Newcall Cfwdall Pickup Dnd
softkeys seized Redial Endcall Cfwdall Pickup
softkeys connected Hold Endcall Trnsfer Confrn
type 7961 addon 1 7914
ephone-template 2
type 7941
Correct Answer by Rob Huffman about 8 years 5 months ago
Hi Dany,
It looks like you are hitting this bug, have a look;
CSCsg87192 Bug Details
Headline 79x1 phone delay to display system message after deactivate DND
First Found-in Version 8.0(3)
First Fixed-in Version 8.3(0.12), 8.2(1.5)
Symptom:
79x1 (7961 and 7941) with cme 4.0.3 delay around 30 seconds to display system message after user deactivate Do Not Disturb via pressing softkey.
Customer activate DND by pressing the DND softkey and the screen changes to "DND" instead of system message which is fine, however, when customer deactivate it...it takes approximately 30 seconds for the DND to change back to the system message.
Conditions:
The problem is only with SCCP41.8-0-4ES4-0-1S and SCCP11.8-0-4SR1S, and NOT seen on earlier firmware like TERM41.7-0-3-0S. It is not seen on 7940/7960 as well.
Hope this helps!
Rob
Overall Rating: 5 (3 ratings)
Correct Answer
Rob Huffman Thu, 12/11/2008 - 06:09
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Dany,
Symptom:
Conditions:
Hope this helps!
Rob
dany.datacraft Thu, 12/11/2008 - 06:33
Thanks Rob!
The description matches what I'm experiencing. I'll try to downgrade/upgrade the firmware tmr.
Best regards,
Dany
Rob Huffman Thu, 12/11/2008 - 06:47
  • Hall of Fame,
    Founding Member
Hi Dany,
You are most welcome my friend! I would look at upgrading rather than downgrading. The 7.x loads were filled with Bugs that may introduce more problems rather than less :)
Hope this helps!
Rob
Rob Huffman Mon, 12/15/2008 - 09:35
  • Hall of Fame,
    Founding Member
Hi Ashish,
Call-forwarding no-answer must be set for a phone to use DND to forward calls. No other configuration is necessary for basic DND.
call-forward noan target-number timeout seconds [primary | secondary] [dialplan-pattern]
Example:
Router(config-ephone-dn)# call-forward noan 2513 timeout 45
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmetrans.html#wpxref44614
Hope this helps!
Rob
dany.datacraft Mon, 12/15/2008 - 18:00
Hi Ashish,
Rob is right. My problem is resolved by upgrading the firmware to 8.2.2SR4.
Hi Rob,
Thanks for the reply.
I was just wondering about the target number. What this number (e.g. 2513) should be? Can it be any number (proxy number) or the number where we need to forward the call?
What's the use of configuring DND, when we are already forwarding the call?
just pardon me if I am sounding weired..
Rgds,
Ashish
Rob Huffman Tue, 12/16/2008 - 05:37
  • Hall of Fame,
    Founding Member
Hi Ashish,
No, these are good questions :) The 2513 is just an example. In most cases this would be some sort of "coverage" number like the Voicemail Pilot# or perhaps an Attendant/back-up person's number.
This reason that DND is different is that the phone that is in DND Mode does not ring like it would with a standard Forward No Answer. This is a nice thing if you are in a meeting or trying to complete an important task without being bothered by a ringing phone.
Hope this helps!
Rob
Rob Huffman Tue, 12/16/2008 - 06:02
  • Hall of Fame,
    Founding Member
Hi Ashish,
WOW!
Thanks so much for your very kind words my friend! These Forums are filled with people trying to help each other, it is always a pleasure to help someone out in a small way :) We all try to "pay it forward" to ensure that our peers are successful in their endevours!
The kindness displayed by people like yourself is really an added bonus!!
Cheers! And Happy Holidays!
Rob
