LMS 3.1 Archive Mgmt failed
Dec 11th, 2008
I can't archive a 3845 router config with RME :
Execution Result:
Unable to get results of job execution for device. Retry the job after increasing the job result wait time using the option:Resource Manager Essentials -> Admin -> Config Mgmt -> Archive Mgmt ->Fetch Settings
I tried this but I got same result.
But I can run a RME job with a command like "show run" successfully.
What could be the problem? I'm using telnet and SNMPV2 with this router.
There is a banner in the config, could it be the problem?
Any idea?
Joe Clarke Thu, 12/11/2008 - 06:50
This may be related to my bug CSCsv95235. Another device might have already wedged ConfigMgmtServer preventing other config archive operations from completing. Try doing:
pdterm ConfigMgmtServer
pdexec ConfigMgmtServer
Then see if this archive job will work.
