CallManager time issue
Dec 11th, 2008
Hi guys. I have an installation of CallManager 6.1 with phone types of 7906, 7921 and 7941. I had an issue with the time in all phones, but I managed to overcome this by correcting the time from the OS Administration page. My problem is that some phones 7941 have a time that is three hours ahead. I checked the device profiles and the time zones and all the phones registered in CallManager using the same.
bigcappa1 Thu, 12/11/2008 - 03:57
  • Silver, 250 points or more
It will come in eventually, try out of hours restarting the CallManager service. I had a similar issue and this is what sorted it
Paul
allan.thomas Thu, 12/11/2008 - 04:20
  • Blue, 1500 points or more
If the devices have the correct DP and timezone, then you should initially try resetting one of the problem phones before restarting CallManager.
Allan.
