Cisco ASA5505
manamsamuel
I have a cisco asa5505 with a base license. Can it be used for site to site and remote access vpn connection at the same time. I seem to be having problems using both options. The site to site is ok but when clients machines connect via remote access they are restricted from accessing resources on the inside interface. Please advise.
Thanks.
12 Replies 12
francisco_1
Level 7
Level 7
yes you can. on the vpn group policy, you need to permit access to the internal network. i beleieve the default acl is any, any apply to the vpn policy group.
look at this link for split-tunnel: http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080702999.shtml
Done all but clients still can't access network resources. Here is my config..
access-list basvpn_splitTunnelAcl standard permit any
access-list inside_nat0_outbound extended permit ip any 192.0.0.224 255.255.255.224
access-list inside_nat0_outbound extended permit ip 192.0.0.0 255.255.0.0 Wxxx 255.255.0.0
access-list inside_nat0_outbound extended permit ip 192.0.0.0 255.255.0.0 192.0.0.224 255.255.255.224
access-list outside_1_cryptomap extended permit ip 192.0.0.0 255.255.0.0 Wxxx 255.255.0.0
access-list civpn_splitTunnelAcl standard permit 192.0.0.0 255.255.0.0
ip local pool basvpnpool 192.0.0.230-192.0.0.250 mask 255.255.0.0
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
route outside 0.0.0.0 0.0.0.0 62.xx.xxx.xx 1
http server enable
http 192.0.0.0 255.255.0.0 inside
no snmp-server location
no snmp-server contact
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set pfs
crypto map outside_map 1 set peer 62.xx.xxx.xxx
crypto map outside_map 1 set transform-set ESP-3DES-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
no crypto isakmp nat-traversal
client-update enable
telnet timeout 5
ssh timeout 5
console timeout 0
tunnel-group-list enable
group-policy basvpn internal
group-policy basvpn attributes
wins-server value 192.0.0.22 192.0.0.21
dns-server value 192.0.0.23 192.0.0.22
vpn-tunnel-protocol IPSec l2tp-ipsec svc
split-tunnel-policy tunnelspecified
split-tunnel-network-list value basvpn_splitTunnelAcl
default-domain value centerprise.co.uk
group-policy civpn internal
group-policy civpn attributes
vpn-tunnel-protocol IPSec svc
split-tunnel-network-list value civpn_splitTunnelAcl
tunnel-group basvpn type remote-access
tunnel-group basvpn general-attributes
address-pool basvpnpool
authentication-server-group ciscobox
default-group-policy basvpn
tunnel-group basvpn ipsec-attributes
pre-shared-key *
tunnel-group 62.xxx.xx.xxx type ipsec-l2l
tunnel-group 62.xxx.xx.xxx ipsec-attributes
pre-shared-key *
tunnel-group civpn type remote-access
tunnel-group civpn general-attributes
default-group-policy civpn
tunnel-group civpn webvpn-attributes
group-alias centerprise enable
tunnel-group civpn ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
Hello Samuel,
Try the following change
ip local VPN_pool basvpnpool 172.16.5.1-172.16.5.254 mask 255.255.255.0
address-pool VPN_pool
no address-pool basvpnpool
no ip local pool basvpnpool 192.0.0.230-192.0.0.250 mask 255.255.0.0
access-list basvpn_splitTunnelAcl standard permit 192.0.0.0 255.255.0.0
no access-list basvpn_splitTunnelAcl standard permit any
crypto isakmp nat-traversal 20
no crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
no crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
no crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
no crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
no crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
no crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
no crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
no crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
no crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
no crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-3DES-SHA
no access-list inside_nat0_outbound extended permit ip 192.0.0.0 255.255.0.0 192.0.0.224 255.255.255.224
access-list inside_nat0_outbound extended permit ip 192.0.0.0 255.255.0.0 172.16.5.0 255.255.255.240
no access-list inside_nat0_outbound extended permit ip any 192.0.0.224 255.255.255.224
manamsamuel
I have made the changes but no luck. I also discovered that when i apply the same configuration to a new asa5505 box without a site to site config it works but both site to site and remote access cannot work on the same box. Is this a license related issue as i currently have a base license.
Thanks.
are u saying that both basvpn, civpn vpn group cannot access anything on the inside?
how is the ASA connected to the inside network. is it connected to a layer 3 switch?
after making the config changes Huseyin asked you to do, can you post the current config on the ASA.
Francisco.
yes both groups cannot access inside network and am connected to a layer 3 hp switch with all port in vlan 1.
I have another cisco ASA5505 box and i configured it for remote access only and all remote clients can access the inside network. If i decide to add site to site service on the same box the remote clients will be denied access to inside interface. So am currently using 2 cisco asa5505, one for site to site vpn to my branch office and the second for remote access clients only.
post your current config from the ASA not working...
hostname Basvpn
enable password 8Ry2YjIyt7RRXU24 encrypted
names
name 192.1.0.0 Wxxx description Wxxx Remote LAN
interface Vlan1
nameif inside
security-level 100
ip address 192.0.0.7 255.255.0.0
interface Vlan2
nameif outside
security-level 0
ip address xxx.xx.xx4.84 255.255.255.240
interface Ethernet0/7
passwd 2KFQnbNIdI.2KYOU encrypted
ftp mode passive
access-list Split_Tunnel_List remark The cooperate Network behind the ASA
access-list Split_Tunnel_List standard permit 172.16.5.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.0.0.0 255.255.0.0 Wales 255.255.0.0
access-list inside_nat0_outbound extended permit ip any 172.16.5.0 255.255.255.0
access-list outside_1_cryptomap extended permit ip 192.0.0.0 255.255.0.0 Wales 255.255.0.0
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
ip local pool basvpnpool 172.16.5.1-172.16.5.254 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-611.bin
no asdm history enable
arp timeout 14400
route outside 0.0.0.0 0.0.0.0 xxx.xxx.x4.94 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
aaa-server ciscobox protocol radius
aaa-server ciscobox host 192.0.0.23
timeout 5
key xxxxxxx
http server enable
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto map outside_map 1 set peer xxx.xxx.x3.1xx
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics
webvpn
wins-server value 192.0.0.21 192.0.0.22
split-tunnel-network-list value Split_Tunnel_List
default-domain value centxxxxx.com
pre-shared-key *
tunnel-group 6xx.xxxx.xxxx type ipsec-l2l
tunnel-group 6xx.xxxx.xxxx ipsec-attributes
pre-shared-key *
parameters
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:ff2de0ced4fd3b6d966d5e79683dfefb
Samuel,
After the users are connected and you do a show crypto ipsec sa, do u see packets making to the ASA.
Also, Is it a requirement to assign the Pool of IP Addresses for the VPN Client from your internal subnet. While, technically this should work, I have seen more issues when configuring VPN Pool from the internal subnet.
Can you change the VPN Pool of IP Address to something totally different from your inside subnet and then do the testing. You also, need to change the Split Tunnel and NAT 0 ACL to reflect the new pool of ip addresses.
Arul
*Pls rate if it helps*
I changed the vpn pool ip to 172.16.5.0 network but still having the same problem. I had to use a spare asa5505 box for remote access vpn only and is all working ok. The question is; why can't i have both site to site and remote access working on one box?
what is your ASA software version.
see below for new changes
no access-list Split_Tunnel_List remark The cooperate Network behind the ASA (OLD
no access-list Split_Tunnel_List standard permit 172.16.5.0 255.255.255.0 (OLD)
access-list basvpnsplit remark internal_access_standard (NEW)
access-list basvpnsplit standard permit host 192.0.0.0 255.0.0.0 (NEW)
access-list basvpn_vpn_acl remark permit_any_extended (NEW)
access-list basvpn_vpn_acl extended permit ip any any (NEW)
split-tunnel-network-list value basvpnsplit (NEW)
vpn-filter value basvpn_vpn_acl (NEW)
no split-tunnel-network-list value Split_Tunnel_List (OLD)
if this doesnt work, because you have made few changes, its better to delete the the existing remote access VPN config in the ASDM. I then run the VPN wizard again but this time do not enable split tunneling in the wizard. configure split tunneling with the CLI. see the link i sent you before for split-tunnel.
Francisco
Francisco,
Still not working after all changes;
sh run
: Saved
ASA Version 8.0(3)
hostname Basvpn
names
name 192.1.0.0 Wxxx description Wxxxx Remote LAN
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address 62x.xx.xxx.xx 255.255.255.240
interface Ethernet0/0
switchport access vlan 2
access-list Split_Tunnel_List remark The corporate network behind the ASA
access-list Split_Tunnel_List standard permit 10.0.1.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.0.0.0 255.255.0.0 10.0.1.0 255.255.255.192
ip local pool basvpnpool 10.0.1.1-10.0.1.50 mask 255.255.255.0
route outside 0.0.0.0 0.0.0.0 6xx.xx.xxx.xxx 1
timeout 5
http server enable
crypto map outside_map 1 set peer 6xx.xx.xx.xxx
encryption 3des
hash sha
group 2
lifetime 86400
webvpn
default-domain value cenxxxxx.cm
pre-shared-key *
tunnel-group 6xx.xx.xx.xxx type ipsec-l2l
tunnel-group 6xx.xxx.xxx.xxx ipsec-attributes
pre-shared-key *
parameters
