UC520 CUE upgrade
Dec 11th, 2008
I'm trying to upgrade cue for uc520 to release 3.2.1.
I've already upgraded CME to the new release but when I try to upgrade CUE with configuratio assistant it fails atthe first backup step.
I own all the correct file both image and language. Do anybody know a safe procedure to upgrade CUE?
irisrios Wed, 12/17/2008 - 07:34
  • Silver, 250 points or more
What is the version of CUE on the module before the upgrade? Are you issuing the CLI software install upgrade or software install clean?
l.buschi Thu, 12/18/2008 - 03:23
I solved my problem. I had a background ftp server which prevented CCA to upgrade the machine.
thanks
JOhnny
