12-11-2008 07:20 AM
Hello
I would like to ask if anbody know why when I use the "cookie insert" option in the CSM configuration with the timeout of 60 minutes, from the browser point of view the cookie expires in 2010? I have checked in on the CSM and CSM-S and in both of them it works the same way.
Thanks in advance
Lukas
Solved! Go to Solution.
12-12-2008 12:22 AM
Its because of the variable (COOKIE_INSERT_EXPIRATION_DATE) that sets the expiry date to Jan 2010. Use "show mod csm X
variable" to see it.
xyz#sh mod csm 3 var | include EXPIRATION
COOKIE_INSERT_EXPIRATION_DATE Fri, 1 Jan 2010 01:01:50 GMT
Setting this variable to none makes it a session cookie ( expire at
the end of the session -- cookie will be erased when the browser is closed).
(config-module-csm)#variable COOKIE_INSERT_EXPIRATION_DATE ""
With "cookie insert feature" on the CSM ,
the timeout value configured in the sticky has no affect. You will always see a timeout of zero.
Syed Iftekhar Ahmed
12-12-2008 12:22 AM
Syed Iftekhar Ahmed
12-12-2008 01:05 AM
Thank you ! It helped :)
Lukas
12-15-2008 11:44 AM
Do you know hy the Internet Explorer 7.0 has problems with cookie inserted by the CSM with expiration date set to session lifetime ?
It seems that the browser is loosing the cookie when the website is being browsed.
Thanks in advance for the answer
Regars
Lukas
