RME inventory failed on cat6509
Dec 11th, 2008
Hello, I am using CWLMS 3.1 with RME 4.2.0, the RME inventory works fine for every switches in the network except for the 2 Catalyst 6509. The IOS version used on these devices is s3223_rp-IPBASEK9-VM, I have no problem with the SNMP community and other credential. The IP address of these 2 devices is 10.128.168.124 and 10.128.168.125, the IC-server log file is attached to this post. Any idea ?
Overall Rating: 5 (1 ratings)
Joe Clarke Thu, 12/11/2008 - 08:04
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I'm seeing some FLASH-MIB timeouts in here. Try increasing the SNMP timeout for these devices under RME > Device Management > RME Devices > Edit Attributes. Without a sniffer trace, I can't say how high to make them, but 10 seconds would be a good start.
jboite Thu, 12/11/2008 - 10:02
It's the solution. I have increased the timeout, the inventory for these 2 devices is collected. Thanks
