Access from DMZ to inside on ASA
This question has 2 parts.
1. I have a web server in the DMZ. It needs to create an SQL/ODBC connection to a server on the inside. I have created an access list entry (x is dmz, y is inside):
access-list dmz_to_inside extended permit tcp host x.x.x.x host y.y.y.y eq 1433
access-group dmz_to_inside in interface dmz
I have also added a static nat:
static (inside,dmz) y.y.y.y y.y.y.y netmask
However, we can't open ODBC connection to the SQL server.
2. Also, this web server needs to be able to browse a folder on a file server that is on the inside. This web server is not a member of the domain. Can anyone assist me with access list entries to allow this short of "permit ip any any"?
Collin Clark Thu, 12/11/2008 - 09:51
Your NAT and ACL look OK. What do your logs say when you try and access the the SQL server? Do you have the DMZ subnet in your internal routing?
