Default route for Branch on MPLS?
Dec 11th, 2008
We want to setup Internet access for our branches ONLY through our regional hub. Currently, branch officesare on MPLS for WAN, and local provider for Internet access.
Question is this: How to set the default route in BGP for each branch to go over MPLS to the regional hub for Internet access, WITHOUT having those default routes propagate througout the global routing table? Some sloppy methods come to mind, but I am looking for the most elegant solution. But don't hesitate to offer up any suggestions! Thanks
Giuseppe Larosa Thu, 12/11/2008 - 09:30
Hello Darren,
neighbor default-originate
To allow a BGP speaker (the local router) to send the default route to a neighbor for use as a default route, use the neighbor default-originate command in address family or router configuration mode. To send no route as a default, use the no form of this command.
neighbor {ip-address | peer-group-name} default-originate [route-map map-name]
no neighbor {ip-address | peer-group-name} default-originate [route-map map-name]
filters towards BGP sessions to other non branch neighbors
ip prefix-list only-default permit
route-map to-nonbranch deny 10
match ip address prefix-list only-default
route-map to-nonbranch permit 20
This should be usable also if you are using MPLS L3 VPN services
Hope to help
Hope to help
