Cisco 2710 - Reset WCS communication password
Dec 11th, 2008
Hi There,
Is there a way to reset the WCS communication password without resetting to factory default?
I would like to change the WCS password but do not have local console access (only SSH). When I re-run the setup script (setup.sh) It does not give me the option for the WCS passowrd.
Any ideas?
Andy
serotonin888 Thu, 12/11/2008 - 12:15
Hi Fella,
Sorry, I probably didnt explain the question very well.
Its the password that is used between the WCS server and a location appliance. (The password entered when you add the location appliance to WCS). It needs to be reset on the location appliance.
Many Thanks
Andy
ericgarnel Fri, 12/12/2008 - 07:41
if you can ssh into the box, cd into /opt/locserver/logs and do the following:
grep -r 'password' *
you should see similar output:
Get-Server-Info-1-0.log: 1/09/06 18:41:51.667 INFO[location] (server,protocol,port,username,password) localhost http 8001 admin ,
default password is admin
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
