Frame-relay traffic-shaping
Answered Question
Dec 11th, 2008
Frame Relay rate limiting :
·Maximum throughput is 128kbps
·During congestion, your provider will mark any traffic in excess of 48kbps as discard eligible,
Make sure your throughput changes accordingly, based upon BECNsreceived, only.
·Your token bucket interval is 125 ms
Config :
map-class frame-relay CIR
frame-relay adaptive-shaping becn
frame-relay cir 128000
frame-relay bc 16000
frame-relay mincir 48000
interface serial 0/0
frame-relay class CIR
frame-relay traffic-shaping
All the gurus, do you think mine config is correct according to the requirement ? Thanks
Correct Answer by Edison Ortiz about 8 years 2 months ago
Looks good. I copied and pasted your config in a router and here is the PVC output.
Shaping adapts to BECN
pvc create time 1d18h, last time pvc status changed 1d18h
cir 128000 bc 16000 be 0 byte limit 2000 interval 125
mincir 48000 byte increment 2000 Adaptive Shaping BECN
HTH,
__
Edison.
Overall Rating: 5 (1 ratings)
Correct Answer
Edison Ortiz Thu, 12/11/2008 - 10:56
HTH,
__
Edison.
