Attendant Console for CUCM 6.1
Answered Question
Gentlemen:
Can anyone tell me what versions of Attendant Console they are running with CUCM 6.1.?? Also, is it downloadable from Cisco's website?
Thanks, Tom D.
Correct Answer by Jaime Valencia about 8 years 5 months ago
you need to install CCM and then from CCMAdmin download the plugin.
Actually in regards to what Rob mentions the only exception to this is CUCM 7 which does provide AC via CCO due to some issues with the new AC consoles which were originally the only ones that were going to be supported.
the original plan was AC would only be provided when upgrading and with AC previously configured, not for any new installs. New installs had to choose from the new AC clients.
java
if this helps, please rate
Correct Answer by Rob Huffman about 8 years 5 months ago
Hi Tom,
I believe these are version specific. You can find the Attendant Console under the plugins page on your CUCM 6.1 Publisher.
These are not available by download as far as I have ever seen.
Hope this helps!
Rob
regular AC is provided with the SW, the version you need is available at plugins from CCMadmin. they are not to be used across versions as they're specific
java
Overall Rating: 5 (3 ratings)
Correct Answer
Jaime Valencia Thu, 12/11/2008 - 10:56
  • Cisco Employee,
  • Hall of Fame,
    2011
java
Correct Answer
Jaime Valencia Thu, 12/11/2008 - 11:05
  • Cisco Employee,
  • Hall of Fame,
    2011
java
Correct Answer
Rob Huffman Thu, 12/11/2008 - 11:00
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Tom,
Hope this helps!
Rob
