locked out of 3560 due to 802.1x
Dec 11th, 2008
co-worker states he is not able to access a 3560 switch (remotely or locally) after it was configured with 802.1x.
Aren't there some white papes out there about this?
thanks, kevin
Overall Rating: 5 (1 ratings)
jpoplawski Thu, 12/11/2008 - 11:19
If you enabled a backup login method, shut down the services on ACS and see if you can get in that way. Beyond that, you'll need to do a password reset on the box.
Hope this helps, rate if it does,
