Device inventory LMS 2.6
Answered Question
Dec 11th, 2008
I have a list of Serial number almost close to 20000. I want to search the device related to this serial number. is there anyways I can add those numbers and Ciscoworks able to compare them or find them.I know I can search base on one serial number but As I said to search multiple Chassis serial number at once.
Thank you
Correct Answer by Joe Clarke about 8 years 7 months ago
You can create an RME inventory custom report, and input all the serial numbers. That will be pretty tedious. It might be easier to create an inventory custom report to look at All serial numbers. Run the report, export it, then run searches from an external source.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Thu, 12/11/2008 - 13:17
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
eliaspaulos Thu, 12/11/2008 - 13:59
Thank you so much J. the second one is easy. I did export to xls and use MS Xcel to compare it.
NIKUFORYOU Wed, 01/07/2009 - 01:34
Hi all,
I am unable to archive the router configurations. when i run the archive job it says as follow -
Failed to fetch config using RCP.Connection refused: connect Verify RCP is enabled or not.
i have checked the running config and RCP is enabled and working.
Can you suggest something?
Joe Clarke Wed, 01/07/2009 - 09:33
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Please start a new thread for your issue.
