Question about ASDM packt tracer function and ping
Dec 11th, 2008
We are getting complaints that is unreachable for vpn users.
I can ping from my local network
I looked at ASDM packt tracer and am not
sure what i would choose as an option for a simple ping test.
I chose the inside interface..
entered the inside interface IP address
gave the destination IP address
and am not sure about code..type..or ID?
any ideas?
husycisco Thu, 12/11/2008 - 11:30
Hello Richard,
It is type=8 code=0 . I suggest you to refrain from using PING while testing availability, when a firewall is involved, or %100 sure that PINGs are permitted through. Following command set for ASA will make sure of it
policy-map global_policy
class inspection_default
inspect icmp
