EIGRP with DMVPN
Answered Question
Dec 11th, 2008
Why there is a need to increase the tunnel interface bandwidth when running EIGRP with DMVPN?
Correct Answer by francisco_1 about 8 years 3 months ago
The default value is 9. The recommend bandwidth value is 1000 or greater. Setting the bandwidth value to at least 1000 is critical if EIGRP is used over the tunnel interface. Higher bandwidth values may be necessary depending on the number of spokes supported by a hub. The bandwidth setting for the spoke does not need to equal the bandwidth setting for the DMVPN hub. It is usually easier if all of the spokes use the same or similar value.
Francisco
Overall Rating: 3 (2 ratings)
Correct Answer
francisco_1 Fri, 12/12/2008 - 06:28
  • Gold, 750 points or more
Francisco
Marwan ALshawi Sun, 12/14/2008 - 13:03
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
by the way
bandiwdth with eigrp with dmvpn used for redundancy
while if u use ospf u can use link cost
hope this helps
