Mesage Queuing Service will not start
Answered Question
Dec 11th, 2008
I have a customer that is having issues with their Unity 4.2 system. It is a VM only system with Exchange on-box. The issue is that the Message Queuing Service fails to start automatically, and cannot be started manually. They are getting an error in the Windows Event Viewer (Application) that states that the Message Queuing Service failed to initialize. Nothing has changed on the system, and no updates have been applied, yet they have this symptom. Obviously, since the Message Queuing Service fails to start, several of the Unity services also fail to start due to their dependancies. What could be causing this? And, more importantly, how can this be resolved?
Thank you for your time and assistance,
Aaron
Correct Answer by Bradford Magnani about 8 years 3 months ago
I've seen this happen many times before... cause really isn't known. Most cases involved a re-installation of Message Queueing. Rarely is it resolved otherwise. This usually requires you to have the OS disc, so have that handy just in case. You can remove and re-add it from Add/Remove Windows Components.
I would also recommend just as a safe-guard to have a good backup of Unity prior.
Hope this helps, if so please rate.
Brad
Overall Rating: 5 (1 ratings)
Correct Answer
Bradford Magnani Thu, 12/11/2008 - 21:08
  • Cisco Employee,
Brad
aaron@3si.net Tue, 12/16/2008 - 07:45
Brad,
Thank you very much for your help with this issue. The re-installation of the Message Queuing Service did the trick. One note, however, is that I ran into an error about "unable to load mqqm.dll" when trying to re-install the MSMQ service. Apparently this is known issue after applying a Microsoft update. So, the fix was to install the MS hotfix MS05-017 prior to the re-installation of the MSMQ service.
Thanks again for your assistance,
Aaron
