pc to access muti vlans on a 2950
Dec 11th, 2008
I am replacing a Cisco 2924 with with a 2950. I have a PC that is accessing vlans 55-61 on the 2924 with the command switchport muti vlan 55-61. What is the command to use on the 2950? I have tried the command :
switchport trunk allow 55-61
switchport mode trunk
on the 2950. Is this the right command to use?
JORGE RODRIGUEZ Sun, 12/14/2008 - 18:50
It seems the multi vlan command feature is only supported on the 2900 and 3500 series switches, personally I have never had the need to used this command but from what I just read although switchport multi vlan is not the same as if you were using dot1q trunk but it resembles same effect , so you may try trunking the port and test it as long the PC NIC supports dot1q you should be good.
the port commands for dot1q encap is:
switchport trunk allowed vlan 2,3,4,5 etc..
