EIGRP output explanation..
Dec 11th, 2008
  • Gold, 750 points or more
Hi All,
Can someone shed some light on the below EIGRP o/p.. Iam trying to figure out '0' successor meaning in R1 and is there anyway I can see the Successors IPs for the networks listed in R2 topology table.
R1:
#sh ip eigrp 29 topology
IP-EIGRP Topology Table for AS(29)/ID(192.168.101.3)
P 0.0.0.0/0, 0 successors, FD is Inaccessible, tag is 100
via 10.40.2.2 (55040/51200), GigabitEthernet3/4
via 10.40.1.2 (51456/51200), GigabitEthernet1/1
P 1.1.1.4/30, 0 successors, FD is Inaccessible
P 192.168.109.0/24, 0 successors, FD is Inaccessible
R2:
P 0.0.0.0/0, 1 successors, FD is 51200, tag is 100
via Redistributed (51200/0)
P 1.1.1.4/30, 1 successors, FD is 51200
P 192.168.109.0/24, 1 successors, FD is 51200
P 192.168.110.0/24, 1 successors, FD is 51200
Thank you
MS
Overall Rating: 4 (1 ratings)
lejoe.thomas Thu, 12/11/2008 - 14:45
  • Silver, 250 points or more
hi Mehboob,
It looks like you're redistributing these routes in eigrp AS 29 or a possible route feedback
This reason why it shows FD as inaccessible is because R1 is not using eigrp routes for the prefixes in the routing table. There could another protocol with a better metric for those routes. Perhaps a show ip route for prefixes in the eigrp topology would help.
In your case since you'd like eigrp routes to be preferred, tweaking the administrative distance to be higher than 170 on the routes from routing protocol which is currently preferred would produce the desired result.
Lejoe
mvsheik123 Fri, 12/12/2008 - 09:08
Thank you. So incase of R2, where it is showing as..
P 192.168.111.0/24, 1 successors, FD is 51200
That means the Successors being learned via redistribution?How do i see who is the successor..?
Thank you
MS
lejoe.thomas Fri, 12/12/2008 - 12:35
You could see it with show ip route prefix.
Lejoe
lejoe.thomas Fri, 12/12/2008 - 19:13
The routes are being redistributed into eigrp, however since the advertised distance is 0 (51200/0), these routes have better metric from another protocol and are not installed in the routing as being learnt from eigrp, since eigrp external routes have an administrative distance of 170.
Eigrp routes for these prefixes are not installed in the routing table, hence there is no successor shown.
Use sh ip eigrp topology [prefix]
should give details regarding the next-hop or successor
Use sh ip route [prefix] to see the details regarding prefix.
Lejoe
