7500 Slave RSP high CPU utilization problem
Dec 11th, 2008
hello guyes
I have a problem about C-7513 Slave RSP high CPU utilization
I've configured for redundancy RSP configuration(SSO, RPR+ )
Router operated correctly.
But I can find HIgh CPU utiliztion on slave RSP(Standby) by 'IPC Slave CBus Process'
Active RSP CPU utilization is normal(0%).
So I want to fix this problem. but i can't find any solution.
somebody help me.
here is what i tried
1) changied IOS version,
- current IOS Version is RSP-K91PV-M Version 12.2(25)S15,
and I tried 12.4.23 (SP/VIP), 12.3.26(SP/VIP)
2) changeed redundancy mode
- RPR+, SSO(SSO mode supports only 12.2(25)S15 release
current RPR+ mode.
3) swaped RSP module
- swaped slot 6 with slot 7 (both are RSP 8)
here is slave RSP output.
#sh proc cp so
CPU utilization for five seconds: 96%/0%; one minute: 95%; five minutes: 95%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
41 5543432 62852623 88 96.39% 95.67% 95.75% 0 IPC Slave CBus p
6 3548 684 5187 0.31% 0.06% 0.05% 0 Check heaps
1 0 5 0 0.00% 0.00% 0.00% 0 Chunk Manager
2 0 1160 0 0.00% 0.00% 0.00% 0 Load Meter
3 168 306 549 0.00% 0.03% 0.00% 0 Exec
4 0 26 0 0.00% 0.00% 0.00% 0 Retransmission o
5 4 44 90 0.00% 0.00% 0.00% 0 IPC ISSU Receive
7 0 1 0 0.00% 0.00% 0.00% 0 Pool Manager
8 0 2 0 0.00% 0.00% 0.00% 0 Timers
9 0 2 0 0.00% 0.00% 0.00% 0 Serial Backgroun
10 0 1 0 0.00% 0.00% 0.00% 0 Policy Manager
11 0 5807 0 0.00% 0.00% 0.00% 0 OIR Handler
12 0 1139 0 0.00% 0.00% 0.00% 0 ALARM_TRIGGER_SC
13 0 97 0 0.00% 0.00% 0.00% 0 IPC Dynamic Cach
#sh redundancy
Redundant System Information :
Available system uptime = 1 hour, 41 minutes
Switchovers system experienced = 0
Hardware Mode = Duplex
Configured Redundancy Mode = rpr-plus
Operating Redundancy Mode = rpr-plus
Maintenance Mode = Disabled
Communications = Up
Current Processor Information :
Standby Location = slot 7
Current Software state = STANDBY COLD-CONFIG
Uptime in current state = 1 hour, 36 minutes
Image Version = Cisco IOS Software, RSP Software (RSP-K91PV-M), Version 12.2(25)S15, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 07-Dec-07 21:16 by tinhuang
BOOT = slot0:rsp-k91pv-mz.122-25.S15.bin,12;
CONFIG_FILE =
BOOTLDR = bootflash:rsp-boot-mz.124-23.bin
Configuration register = 0x102
Peer (slot: 6, state: ACTIVE) information is not available because this is the standby processor
Giuseppe Larosa Fri, 12/12/2008 - 02:42
Hello ChangShik,
first of all verify that you have only VIP linecards in the chassis and no old cpuless Interface processors
see
RPR+ operates only in a system with VIPs as the line cards. Systems with legacy IPs default to RPR mode. Up to two legacy IPs can be supported by RPR+ if the service single-slot-reload-enable command is configured.
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t7/feature/guide/gt_rpr2.html#wp1057189
Legacy IPs default to RPR. To allow RPR+ for VIPs when up to two legacy IPs exist in the router, you must configure the service single-slot-reload-enable command. If you do not enable the service single-slot-reload-enable command or if you have more than two legacy IPs, all the line cards are reloaded.
Hope to help
Giuseppe
