TCL Scripting, need help !
Dec 11th, 2008
Hi all, i have a requirement in which i have to shut and no shut a particular tunnel at around 20+ spokes from the hub. I want to write the script in which it says that go to int tunnel 1 (its always tunnel 1 ) shut and no shut. At each spoke i have authentication through AAA but i am expecting then when i will be doing this activity they will be accessible via local username/pass only which is constant throughout. so this is the steps i need
go to particular WAN IP
enter username
enter password
enable
enter password
conf t
int tun 1
sh
no sh
end
exit
Can some 1 help me write this script ?
Giuseppe Larosa Fri, 12/12/2008 - 04:19
  • Hall of Fame,
    Founding Member
Hello Ovais,
for this kind of things you could use the expect library under tcl.
http://expect.nist.gov/
this is thought to be able to manage interactive logins
only warning: when you shut tunnel1 the branch is still reachable ?
www.activestate.com activetcl 8.4.x or later should have an expect library
you need to build a list of devices ip addresses that will be indexed in a for cycle and in the for body there the instructions for performing the required actions
I used it and it works well. I had used a 5.21 version of porting to windows
if you have a linux box it should be even easier
commands are
expect "sername"
send $user
expect "assoword"
send $pass
during configuration the expect should match only the hostname
Hope to help
Giuseppe
