Converting 1242AG-S-K9 to ETSI
Dec 11th, 2008
I have a 1242AG accesspoint which is currently in singapore config. If i use this device in Europe i get very low signal on the Laptops belongs to europe users. If i use singapore laptops then i get full signal.
Is there anyway i can change the Access point to ETSI config?? Any IOS upgrade can help?
Manoj
Rob Huffman Fri, 12/12/2008 - 06:00
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Manoj,
Sadly, this cannot be changed in the field. Here is a paraphrase from Cisco doc's;
Access points are designed for use in many countries with varying regulatory requirements. The radios within the access points are assigned to a specific regulatory domain at the factory (such as -E for Europe), the country code ensures that each radio's broadcast frequency bands, interfaces, channels, and transmit power levels are compliant with country-specific regulations.
Hope this helps!
Rob
tomathur Fri, 01/16/2009 - 11:34
Sorry Manoj.You will have to buy a new AP from Cisco with the software image containing E in the name.It designates that the AP is meant to be used in European regulatory domain.This is embedded on the chipset(hardware).No IOS(software) upgrade can help.
Manish Mathur
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
