checking CSM status via SNMP
Dec 12th, 2008
Hello
Does anybody what SNMP OID should be pooled to check the redundancy state of the CSM module ? I would like to check if the module is in the active or standby role.
Thanks in advance
Lukas
Syed Iftekhar Ahmed Fri, 12/12/2008 - 12:39
  • Blue, 1500 points or more
From my notes ..
See if its still valid
MIB: CISCO-SLB-EXT-MIB:cslbxFtState.9
OID: 1.3.6.1.4.1.9.9.254.1.10.1.1.7.9
The last digit is the slot where the CSM module is installed.
Possible Return Values:
1 means not configured
2 means Initializing
3 means Active
4 means Standby
Syed Iftekhar Ahmed
