WAVE - disk allocation
lampardbri
I understand that the way how the disks are partitioned for DRE/WAFS varies according to different models.
Does anyone have any info regarding the new WAVE appliances? DRE vs WAFS vs Virtual blade?
thanks
ropethic
Level 4
Level 4
When the VB is enabled, it requires a reload. Once reloaded the disk is repartioned for DRE, CIFS and VB.
The number of Virtual Blades supported and the total disk capacity available for Virtual Blade allocation varies with the WAE or WAVE device model and the amount of memory available on the device:
Platform VBs HD (GB)
WAVE-274 1 35
WAVE-474 1 35
WAVE-574/3GB 1 60
WAVE-574 /6GB 3 180
WAE-674 /4GB 3 120
WAE-674 /8GB 3 200
Thanks! Can you tell me how much disk allocated for the DRE vs CIFS for each model as well?
WAVE-274
WAVE-474
WAVE-574/3GB
WAVE-574/6GB
WAE-674/4GB
WAE-674/8GB
