Import notes for end hosts already discovered
Dec 12th, 2008
Currently we are testing LMS 3.1, Campus manager. For some reason we want to import some extra info into the notes field.
Is it done using a CSV file ? I added the extra info after the "last seen" field. When importing CM sais the import is done, but nothing is changed when info is asked. Any ideas ?
"",00-80-9f-77-18-bd,,,,hsrinsa34, Fa0/13 ,IpTel_RingstationA_0,2008/12/12 10:06:08,""
Many thanks,
Lieven Stubbe
Joe Clarke Fri, 12/12/2008 - 09:05
Make sure the file format is preserved EXACTLY. The header in the CSV file is important. For example, your file should look like:
Campus User Tracking
End Hosts Immediate Report as of 12 Dec 2008, 12:03:23 EST
Last User Tracking Started at : 12 Dec 2008, 10:00:00 EST. Ended at : 12 Dec 2008, 10:01:40 EST. Completed in 1 minutes 40 seconds.
User Name,MAC Address,Host Name,IP Address,Subnet,Device Name,Port,VLAN,Last Seen,Notes
