Slip errors increasing in E1 Contolller + Interface
bagvanliju
I am facing Slip error in two contoller E1 ports.Service provider tested the link several times with error free...router vender came and tested every thing gave the update all are fine ...changed the E1 controller card and also the router ...no use
any body have any idea about the same ....would be very much helpfull ..this is an on going issue ....
below is the out put taken from router ...any inputs.even cisco tac told no issue with router ....i am running a multi link with 5 E1s ....
E1 0/3/1 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20071011, FPGA: 13, spm_count = 0
Framing is UNFRAMED, Line Code is HDB3, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (820 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
445 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
445 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
XXXXX#show controller
Interface GigabitEthernet0/0 (idb 0x66F90EDC)
Hardware is BCM1125 Internal MAC (Revision A3)
network link is up
Config is 100Mbps, Full Duplex
Selected media-type is RJ45
SFP is not present
MAC Registers:
E1 0/2/1 is up.
No alarms detected.
215 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
215 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
XXXXX#s ver
Cisco IOS Software, 3800 Software (C3845-ADVIPSERVICESK9-M), Version 12.4(15)T4,
RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 13-Mar-08 09:02 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
XXXX uptime is 20 weeks, 6 days, 3 hours, 11 minutes
System restarted at 03:15:09 UTC Sat Jul 19 2008
System image file is "flash:c3845-advipservicesk9-mz.124-15.T4.bin"
ujil
5 Replies 5
cfolkerts
I had a similar problem a while back. Here is the response that I reveived from Cisco TAC.
The second port on a 2 T1 VWIC will have to be set to clock source internal because the 2 port VWIC has a single common clocking chip in it. Two clock sources to each of the ports on the same VWIC will result in slips.
Set the second port to internal, on both vwics. This will fix it.
Hai Clifton,
Thanks for the reply,This is a multilink with 5 E1 MPLS connnectivity.ISP had shared the Error report in PE router...no erros observed in their sonet (for 5 KLMs)...both end clock source is line.. SDH is generating the clock ...in this case any suggestion .so just one more confirmation can i change the clock source to internal for second port ???
kindly reply
ujil
read Slip Secs Counter Increasing on the following link. Maybe can be helpful
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a00801095a3.shtml
Yes, you can change the clock source to internal for the second port. The configuration is done under the controller config.
Thanks for the update ..still working on it ..will do the same and share the results ...
ujil
