BCMSN Practice
Dec 12th, 2008
Quick question...
Is it possible to use dynamips for practising the BCMSN like you can for the BSCI?
I think not as the dynagen/dynamips just has routers and no switches (well except for one but its a dumb switch)
Is there anything else that can be used?
cameron.moody Fri, 12/12/2008 - 08:50
You should be able to do everything you need for BCMSN if you add a switching module to one of the routers.
Urfan Khaliq Fri, 12/12/2008 - 09:26
what routers would you recommend and how many would you need to run at one time? (need an idea of how cpu intensive it would be)
johnlloyd_13 Fri, 12/12/2008 - 22:14
i remembered using dynamips with 3640 ios for my bcmsn practice labs. you can lower your cpu with idlepc values. there is a tutorial on dynamips webpage on how to do this.
