ASA5510 PPPoE DNS
Dec 12th, 2008
Hi All !
I have set up an ASA5510 to access internet using a DSL line via PPPoE.
The PPPoE client connects, authenticates and almost everything is fine, except the DNS server. Normally, the ISP provides the DNS server for the PPPoE client to use, anthis can be pushed to clients via DHCP.
This is what I cannot do with ASA. I can't find any command either in CLI or ASDM to tell ASA to request the DNS server address, and publish it to its clients via DHCP.
Is this functionality present in ASA at all ?
Laszlo
irisrios Thu, 12/18/2008 - 11:36
  • Silver, 250 points or more
ASA supports operating as both Dynamic Host Configuration Protocol (DHCP) servers and DHCP clients. DHCP supplies automatic configuration parameters such as an IP address with a subnet mask, default gateway, DNS server, and WINS server IP address to hosts.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00806c1cd5.shtml
franklaszlo Sat, 12/20/2008 - 01:02
Thanks, I konow ASA supports DHCP operations, my question was concernig explicitly the interoperation between DHCP server and PPPoE client.
However, in the meantime I figured it out, it is the "dhcpd auto_config interface" command what does the trick :-)
