Dual ISP 877 is this going to work?
Dec 12th, 2008
I have setup a 877 with Adv IP as follows but I can't test till I get to site so not sure if this will work.
VLAN2 - Linked FE3 - ISP2
VLAN1 - Internal
I have created PBR for NAT.
I have an IP SLA track to mark the routes.
I've done this before on 1800s I think this is OK but I need to create a VPN tunnel that will switch interfaces in the event the main VLAN2 goes down. This is the bit i'm not 100% I can do.
I've attached the config.
They've changed the CBAC and ACL to this new Zones method and it confusing me a bit.
robertpatrick Wed, 12/31/2008 - 16:14
Using a VPN that is tied to a physical interface which is one of your ISP uplinks is likely to fall down if that ISP uplink is down.
