"admin-context" command not available on FWSM
Answered Question
Dec 12th, 2008
Hi gurus,
Probably, I have a totally stupid newbie question. I got a new Cisco FWSM and trying to configure from scratch. Looks like command "admin-context" is not available from firewall configuration mode. Is it a licensing problem? Am I in a wrong mode? Thank you!
FW# show ver
FWSM Firewall Version 3.2(5)
Compiled on Mon 10-Mar-08 16:03 by fwsmbld
FW up 16 days 3 hours
Hardware: WS-SVC-FWM-1, 1024 MB RAM, CPU Pentium III 1000 MHz
Flash STI Flash 8.0.0 @ 0xc321, 20MB
0: Int: Not licensed : irq 5
1: Int: Not licensed : irq 7
2: Int: Not licensed : irq 11
The Running Activation Key is not set, using default settings:
Licensed features for this platform:
Maximum Interfaces : 256
Inside Hosts : Unlimited
Failover : Active/Active
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Cut-through Proxy : Enabled
Guards : Enabled
URL Filtering : Enabled
Security Contexts : 2
GTP/GPRS : Disabled
BGP Stub : Disabled
VPN Peers : Unlimited
Serial Number: SAD123602JE
Running Activation Key: 0x00000000
0x00000000 0x00000000 0x00000000
Configuration last modified by enable_15 at 14:46:41.458 UTC Fri Dec 12 2008
config)# ?
aaa Enable, disable, or view user authentication,
authorization and accounting
aaa-server Configure a AAA server group or a AAA server
access-group Bind an access-list to an interface to filter traffic
access-list Configure an access control element
alias Administer overlapping addresses with dual NAT
arp Change or view ARP table, set ARP timeout value, view
statistics
asdm Configure Device Manager
auth-prompt Customize authentication challenge, reject or
acceptance prompt
auto-update Configure Auto Update
banner Configure login/session banners
ca Certification authority
<skipped>
url-block Enable URL pending block buffer and long URL support
url-cache Enable/Disable URL caching
url-server Configure a URL filtering server
username Configure user authentication local database
virtual Configure address for authentication virtual servers
vpn-addr-assign Global settings for VPN IP address assignment policy
vpn-sessiondb Configure the VPN Session Manager
vpngroup Configure a policy group for VPN clients
xlate-bypass Enable/Disable xlate bypass
Correct Answer by Jon Marshall about 8 years 2 months ago
Type "sh mode".
If it's says "single" then you are in wrong mode. To change to multiple mode -
http://www.cisco.com/en/US/docs/security/fwsm/fwsm32/configuration/guide/contxt_f.html#wp1051132
Note what happens to the existing config.
If it says "multiple" try entering
"ch sys"
Jon
Overall Rating: 5 (1 ratings)
