BGP receives incomplete table route
Dec 12th, 2008
Hi team, I am having troubles with a Cisco 2801 running Version 12.4(7a) and in another running 12.4(9) IOS version. The problem is that sometimes they receive about 500 routes when their neigbour advertises about 1600; but some times BGP works good and they receive 1600 like as it is supposed to be, but if after a moment you run a "clear bgp*" the routes desappear after and then after the router syncronize bgp again the route table is incomplete with about only 500 routes again.
Here I attach show-tech file that belongs to one router 2800 with this issue.
The problem is with AS bgp 65200, with for example neighbor
Is there any known workaround?
Thanks a lot Team
Best regards to all
Giuseppe Larosa Fri, 12/12/2008 - 10:00
hello Gabriel,
your router is in AS65200
the neighbor is in as10834
you accept up to 10 times your own AS 65200 in updates
neighbor allowas-in 10
you also have iBGP neighbors from which you not accept anything
neighbor distribute-list local in
ip access-list extended local
deny ip any any
and you try to do AS path prepending to your iBGP neighbor (as path attribute is not changed this should be not effective)
neighbor route-map prepend out
this last command is wrong in my opinion
you should think to send few summarized routes to this device.
1500 routes inside a VPN if in all cases you need to send traffic to the same neighbor you don't need to receive all this detail
Hope to help
