Basic conf ASA 5505
p.maillot
I'm a newbie on ASA, I need some assistance.
I have this schema.
Host 192.168.1.0/ ---> ASA INSIDE ----->ASA OUTSIDE ------> to my interface router
From host 192.168.1.0/24 I can ping INSIDE interface from my ASA but I cannot ping interface OUTISIDE and no interface from my router at this address 172.16.0.5/252
Under my conf.
ASA Version 7.2(4)
hostname ciscoasa
domain-name default.domain.invalid
enable password 1I5BT/dHhpGbnQvr encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 100
ip address 172.16.0.6 255.255.255.252
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
dns server-group DefaultDNS
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list inside_access_in extended permit ip any any
access-list outside_access_in extended permit ip any any
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-524.bin
no asdm history enable
arp timeout 14400
nat-control
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 172.16.0.5 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.2-192.168.1.33 inside
dhcpd enable inside
username admin password p1ClWSkbSujddlxc encrypted
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:885202205e413b4a47e7f59d572ef3d7
: end
2 Accepted Solutions
Collin Clark
From the inside host you are not allowed to ping the outside interface (that's part of the security of the firewall). From the router you should be able to ping the outside IP though. Try adding this line-
icmp permit any outside
Try pinging and if it fails, take a look at the log show logging buff | inc ICMP and see where it's failing.
Hope that helps.
Hello Pascal,
Please do the following
(Assuming that NAT for internet connection etc does not take place in router for 192.168.1.0/24 network)
nat (inside) 1 0 0
global (outside) 1 interface
interface Vlan2
security 0
no same-security-traffic permit inter-interface
no same-security-traffic permit intra-interface
no access-list inside_access_in extended permit ip any any
no access-list outside_access_in extended permit ip any any
no access-group inside_access_in in interface inside
no access-group outside_access_in in interface outside
inspect icmp
34 Replies 34
Collin Clark
Hope that helps.
Thank Collin but no change with
icmp permit any outside and icmp permit any inside
This command don't exist show logging buff | inc ICMP.
I can do only
ciscoasa# sh logging ?
asdm Show ASDM syslog buffer content
message Show enabled and disabled messages at non-default level
queue Show syslog queue
setting Show syslog setting
| Output modifiers
try access-list outside_access_in extended permit icmp any any
Francisco
should work.
access-list outside_access_in permit icmp any any echo-reply
access-list outside_access_in permit icmp any any source-quench
access-list outside_access_in permit icmp any any unreachable
access-list outside_access_in permit icmp any any time-exceeded
Sorry, show logging is correct.
Always same problem with
And after sh logging?
Syslog logging: disabled
Facility: 20
Timestamp logging: disabled
Standby logging: disabled
Deny Conn when Queue Full: disabled
Console logging: disabled
Monitor logging: disabled
Buffer logging: disabled
Trap logging: disabled
History logging: disabled
Device ID: disabled
Mail logging: disabled
ASDM logging: level informational, 0 messages logged
Same problem with.
Hello Pascal,
nat (inside) 1 0 0
interface Vlan2
security 0
inspect icmp
Jon Marshall
nat (inside) 1 192.168.1.0 255.255.255.0
Jon
now why didnt i though of that :)
good job jon
Same problem. See my last conf
ASA Version 7.2(4)
hostname ciscoasa
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ftp mode passive
access-list outside_access_in extended permit icmp any any echo-reply
access-list outside_access_in extended permit icmp any any source-quench
access-list outside_access_in extended permit icmp any any unreachable
access-list outside_access_in extended permit icmp any any time-exceeded
pager lines 24
mtu inside 1500
mtu inside 1500
mtu outside 1500
arp timeout 14400
nat-control
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd enable inside
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect icmp
: end
ciscoasa(config)#
use "sh logg | inc icmp" under CLI and post outout.
When I use "sh logg | inc icmp" under CLI, nothing appears.
Config looks OK, now please explain the problem in details. Please keep in mind that by default, you can NOT! ping the inside interface of ASA from your router connected to outside interface. And with this configuration, you can NOT! ping hosts in 192.168.1.0/24 on their actual IPs since they are NATed. If you describe what you exactly want to achieve, then we will advise accordingly
