Switching
Get 20% off switches when you combine Cisco solutions
Labels
Hi, I am working on a RFP where one of the specs says " the switch should support IEEE802.3ah ethernet link OAM and IEEE 802.1ag/ITU-T Y.1731" this is the only point which i am not able to find a reference in cisco documents, though we have a cisco 9...
Hi, I have a C2960L-SM and noticed that I can't connect over ssh anymore. I getssh_exchange_identification: Connection closed by remote host If I run show ip ssh it seems ssh is running:SSH Enabled - version 1.99 ... and so on What can I do? Especial...
tokon by Level 1
  • 7432 Views
  • 23 replies
Resolved! vmware nic teaming
Hi, if NIC are teamed on VMWARE  and set to "route based on the orginating virtual id" do i need to port-channel on the cisco switch ?
Guys I am trying to determine what the difference between "full poe" and "poe"I am replacing a few WS-C3560G-48PS-S switches at my clients and need to make sure I am providing them with the same PoE functionality that they currently have with the WS-...
a-belesimo by Level 1
  • 17349 Views
  • 8 replies
I think I already know the answer to this.Will an SFP-10G-SR work in the 4G model if the interface is set to 'speed 1000' ?It currently keeps err-disabling in the 9200, even with speed at 1000I have a 9200 connected to a CBS350 (which I am sure will ...
sw# show system resourcesLoad average:   1 minute: 0.33   5 minutes: 0.38   15 minutes: 0.31Processes   :   576 total, 1 runningCPU states  :   0.25% user,   1.00% kernel,   98.74% idle                CPU0 states  :   0.00% user,   0.00% kernel,   10...
Is there a better way to upgrade these yet?Obviously, I want to reboot after-hours. The install command still cannot be scheduled.install add file flash:cat9k_iosxe.17.09.05.SPA.bin activate commit prompt-level noneIf I do not do prompt-level none th...
