Can a single CUCM register to a GK more then once?
Dec 12th, 2008
Can you register a single CUCM to a single GK but to more then one zone so the CUCM is registered as two, three zones. Attached is a screen shot of the trunk configuration, it mentions that you add the name of the zone against a trunk and this name is used as a zone within the GK so in theory you can register multiple trunks against different zones?. I`ve been told by an SI that you can not do this and if you wanted more then one zone to be registered to the same GK from a single CUCM you need to use a trunk registered to the GK for one zone and then use a CUCM controlled GW to register to the GK as a second zone. The reason I`m asking is that I need to have two zones with different bandwidth controls for voice and video- both the voice and video devices will register to the same CUCM- thanks
